Ising systems, measures on the sphere, and zonoids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Tunisian Journal of Mathematics Année : 2023
We give an interpretation of a class of discrete-to-continuum results for Ising systems using the theory of zonoids. We define the classes of rational zonotopes and zonoids, as those of the Wulff shapes of perimeters obtained as limits of finite-range homogeneous Ising systems and of general homogeneous Ising systems, respectively. Thanks to the characterization of zonoids in terms of measures on the sphere, rational zonotopes, identified as finite sums of Dirac masses, are dense in the class of all zonoids. Moreover, we show that a rational zonoid can be obtained from a coercive Ising system if and only if the corresponding measure satisfies some ‘connectedness’ properties, while it is always a continuum limit of ‘discrete Wulff shapes’ under the only condition that the support of the measure spans the whole space. Finally, we highlight the connection with the homogenization of periodic Ising systems and propose a generalized definition of rational zonotope of order N , which coincides with the definition of rational zonotope if N=1.
hal-04320040 , version 1 (03-12-2023)
Andrea Braides, Antonin Chambolle. Ising systems, measures on the sphere, and zonoids. Tunisian Journal of Mathematics, inPress. ⟨hal-04320040⟩
20 Consultations
0 Téléchargements
