Towards filling the gaps around recurrent events in high dimensional framework: a systematic literature review and application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biostatistics & Epidemiology Année : 2023
Individuals may experience repeated events over time. However, there is no consensus about learning approaches to use in a high-dimensional framework for survival data (when the number of variables exceeds the number of individuals, i.e. p > n). The aim of this study was to identify learning algorithms for analyzing/predicting recurrent events, and to compare them to standard statistical models on simulated data. A systematic literature review was conducted to provide state-of-the-art methodology. Data were then simulated according to the number of variables, the proportion of active variables, and the number of events. The performance of the models was assessed using Harrell’s concordance index, Kim’s C-index, and error rate for active variables. Seven publications were identified, of which four were methodological studies, one an application paper and two were reviews. On simulated data, the standard models failed when p > n. Penalized Andersen–Gill and frailty models outperformed, whereas RankDeepSurv gave poorer performances. With no current guidelines on a specific approach to use, this study deepens understanding of the mechanisms and limits of investigated methods in this context.
Fichier non déposé
hal-04320229 , version 1 (04-12-2023)
Juliette Murris, Anais Charles-Nelson, Abir Tadmouri Sellier, Audrey Lavenu, Sandrine Katsahian. Towards filling the gaps around recurrent events in high dimensional framework: a systematic literature review and application. Biostatistics & Epidemiology, 2023, 7 (1), ⟨10.1080/24709360.2023.2283650⟩. ⟨hal-04320229⟩
64 Consultations
0 Téléchargements
