A robust and adaptive GenEO-type domain decomposition preconditioner for $\mathbf{H}(\mathbf{curl})$ problems in general non-convex three-dimensional geometries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this paper we develop and analyse domain decomposition methods for linear systems of equations arising from conforming finite element discretisations of positive Maxwell-type equations, namely for $\mathbf{H}(\mathbf{curl})$ problems. It is well known that convergence of domain decomposition methods rely heavily on the efficiency of the coarse space used in the second level. We design adaptive coarse spaces that complement a near-kernel space made from the gradient of scalar functions. The new class of preconditioner is inspired by the idea of subspace decomposition, but based on spectral coarse spaces, and is specially designed for curl-conforming discretisations of Maxwell's equations in heterogeneous media on general domains which may have holes. Our approach has wider applicability and theoretical justification than the well-known Hiptmair-Xu auxiliary space preconditioner, with results extending to the variable coefficient case and non-convex domains at the expense of a larger coarse space.
hal-04321182 , version 1 (04-12-2023)
Niall Bootland, Victorita Dolean, Frédéric Nataf, Pierre-Henri Tournier. A robust and adaptive GenEO-type domain decomposition preconditioner for $\mathbf{H}(\mathbf{curl})$ problems in general non-convex three-dimensional geometries. 2023. ⟨hal-04321182⟩
24 Consultations
0 Téléchargements
