BadVFL: Backdoor Attacks in Vertical Federated Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Federated learning (FL) enables multiple parties to collaboratively train a machine learning model without sharing their data; rather, they train their own model locally and send updates to a central server for aggregation. Depending on how the data is distributed among the participants, FL can be classified into Horizontal (HFL) and Vertical (VFL). In VFL, the participants share the same set of training instances but only host a different and non-overlapping subset of the whole feature space. Whereas in HFL, each participant shares the same set of features while the training set is split into locally owned training data subsets. VFL is increasingly used in applications like financial fraud detection; nonetheless, very little work has analyzed its security. In this paper, we focus on robustness in VFL, in particular, on backdoor attacks, whereby an adversary attempts to manipulate the aggregate model during the training process to trigger misclassifications. Performing backdoor attacks in VFL is more challenging than in HFL, as the adversary i) does not have access to the labels during training and ii) cannot change the labels as she only has access to the feature embeddings. We present a first-of-its-kind clean-label backdoor attack in VFL, which consists of two phases: a label inference and a backdoor phase. We demonstrate the effectiveness of the attack on three different datasets, investigate the factors involved in its success, and discuss countermeasures to mitigate its impact.
313000a008.pdf (597.9 Ko) Télécharger le fichier
Licence : Domaine public
hal-04321905 , version 1 (04-12-2023)
Paternité
  • HAL Id : hal-04321905 , version 1
Mohammad Naseri, Yufei Han, Emiliano de Cristofaro. BadVFL: Backdoor Attacks in Vertical Federated Learning. SP 2024 - IEEE Symposium on Security and Privacy, May 2024, San Francisco, United States. pp.1-8. ⟨hal-04321905⟩
155 Consultations
18 Téléchargements
