Vehicle Motion Forecasting using Prior Information and Semantic-assisted Occupancy Grid Maps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Motion prediction is a challenging task for autonomous vehicles due to uncertainty in the sensor data, the non-deterministic nature of future, and complex behavior of agents. In this paper, we tackle this problem by representing the scene as dynamic occupancy grid maps (DOGMs), associating semantic labels to the occupied cells and incorporating map information. We propose a novel framework that combines deep learning-based spatio-temporal and probabilistic approaches to predict vehicle behaviors. Contrary to the conventional OGM prediction methods, evaluation of our work is conducted against the ground truth annotations. We experiment and validate our results on real-world NuScenes dataset and show that our model shows superior ability to predict both static and dynamic vehicles compared to OGM predictions. Furthermore, we perform an ablation study and assess the role of semantic labels and map in the architecture.
IROS2023_arxiv.pdf (5.81 Mo) Télécharger le fichier
hal-04331648 , version 1 (08-12-2023)
Paternité
  • HAL Id : hal-04331648 , version 1
Rabbia Asghar, Manuel Alejandro Diaz-Zapata, Lukas Rummelhard, Anne Spalanzani, Christian Laugier. Vehicle Motion Forecasting using Prior Information and Semantic-assisted Occupancy Grid Maps. IROS 2023 - IEEE/RSJ International Conference on Intelligent Robots and Systems, Oct 2023, Detroit, Michigan, United States. pp.1-6. ⟨hal-04331648⟩
46 Consultations
12 Téléchargements
