An LMI-based Robust Nonlinear Adaptive Observer for Disturbed Regression Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2023
This article deals with the problem of timevarying parameter identification in dynamical regression models affected by disturbances. The disturbances comprise timedependent external perturbations and nonlinear unmodeled dynamics. With this aim in mind, we propose a robust nonlinear adaptive observer. The algorithm ensures the asymptotic convergence of the parameter identification error to an acceptably small region around the origin in the presence of disturbances. The synthesis of the adaptive observer is given in terms of linear matrix inequalities, providing a constructive design method. An academic example and a low inertia power system illustrate the robustness and the applicability of the proposed adaptive observer for the time-varying parameter identification problem.
Automatique
_main.pdf (1.3 Mo) Télécharger le fichier
hal-04333541 , version 1 (10-12-2023)
Paternité
  • HAL Id : hal-04333541 , version 1
Héctor Ríos, Alejandra Ferreira de Loza, Denis Efimov, Roberto Franco. An LMI-based Robust Nonlinear Adaptive Observer for Disturbed Regression Models. IEEE Transactions on Automatic Control, In press. ⟨hal-04333541⟩
18 Consultations
43 Téléchargements
