The Nullstellensatz and Positivstellensatz for Sparse Tropical Polynomial Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
Marianne Akian
  • Fonction : Auteur
Antoine Béreau
Stéphane Gaubert
Grigoriev and Podolskii (2018) have established a tropical analogue of the effective Nullstellensatz, showing that a system of tropical polynomial equations is solvable if and only if a linearized system obtained from a truncated Macaulay matrix is solvable. They provided an upper bound of the minimal admissible truncation degree, as a function of the degrees of the tropical polynomials. We establish a tropical Nullstellensatz adapted to sparse tropical polynomial systems. Our approach is inspired by a construction of Canny-Emiris (1993), refined by Sturmfels (1994). This leads to an improved bound of the truncation degree, which coincides with the classical Macaulay degree in the case of n + 1 equations in n unknowns. We also establish a tropical Positivstellensatz, allowing one to decide the inclusion of tropical basic semialgebraic sets. This allows one to reduce decision problems for tropical semi-algebraic sets to the solution of systems of tropical linear equalities and inequalities.
article-tropical-nullstellensatz.pdf (587.89 Ko) Télécharger le fichier
Licence : Copyright (Tous droits réservés)
hal-04333931 , version 1 (10-12-2023)
Marianne Akian, Antoine Béreau, Stéphane Gaubert. The Nullstellensatz and Positivstellensatz for Sparse Tropical Polynomial Systems. 2023. ⟨hal-04333931⟩
24 Consultations
5 Téléchargements
