Multifractality in spin glasses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the National Academy of Sciences of the United States of America Année : 2023
Isidoro González-Adalid Pemartín
Antonio Muñoz Sudupe
  • Fonction : Auteur
Juan Jesús Ruiz-Lorenzo
Beatriz Seoane
We unveil the multifractal behavior of Ising spin glasses in their low-temperature phase. Using the Janus II custom-built supercomputer, the spin-glass correlation function is studied locally. Dramatic fluctuations are found when pairs of sites at the same distance are compared. The scaling of these fluctuations, as the spin-glass coherence length grows with time, is characterized through the computation of the singularity spectrum and its corresponding Legendre transform. A comparatively small number of site pairs controls the average correlation that governs the response to a magnetic field. We explain how this scenario of dramatic fluctuations (at length scales smaller than the coherence length) can be reconciled with the smooth, self-averaging behavior that has long been considered to describe spin-glass dynamics.
2306.04591.pdf (2.13 Mo) Télécharger le fichier
hal-04344056 , version 1 (04-04-2024)
Paternité
Marco Baity-Jesi, Enrico Calore, Andrés Cruz, Luis Antonio Fernández, José Miguel Gil-Narvión, et al.. Multifractality in spin glasses. Proceedings of the National Academy of Sciences of the United States of America, In press, 121 (2), ⟨10.1073/pnas.2312880120⟩. ⟨hal-04344056⟩
37 Consultations
2 Téléchargements
