A manual categorization of new quality issues on automatically-generated tests - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Diverse studies have analyzed the quality of automatically generated test cases by using test smells as the main quality attribute. But recent work reported that generated tests may suffer a number of quality issues not necessarily considered in previous studies. Little is known about these issues and their frequency within generated tests. In this paper, we report on a manual analysis of an external dataset consisting of 2,340 automatically generated tests. This analysis aimed at detecting new quality issues, not covered by past recognized test smells. We use thematic analysis to group and categorize the new quality issues found. As a result, we propose a taxonomy of 13 new quality issues grouped in four categories. We also report on the frequency of these new quality issues within the dataset and present eight recommendations that test generators may consider to improve the quality and usefulness of the automatically generated tests.
conference_101719.pdf (226.53 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-04344531 , version 1 (14-12-2023)
Paternité
Geraldine Galindo-Gutierrez, Narea Maxilimiliano, Blanco Alison Fernandez, Nicolas Anquetil, Alcocer Juan Pablo Sandoval. A manual categorization of new quality issues on automatically-generated tests. Proceedings of the 39st IEEE International Conference on Software Maintenance and Evolution (ICSME'23), IEEE computer society, Oct 2023, Bogota, Colombia. ⟨10.1109/ICSME58846.2023.00035⟩. ⟨hal-04344531⟩
51 Consultations
19 Téléchargements
