Measuring Neuronal Avalanches to inform Brain-Computer Interfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue iScience Année : 2023
Leonardo L. Gollo
  • Fonction : Auteur
  • PersonId : 900115
Sophie Dupont
  • Fonction : Auteur
  • PersonId : 889741
Danielle S Bassett
  • Fonction : Auteur
  • PersonId : 1079134
Viktor Jirsa
Large-scale interactions among multiple brain regions manifest as bursts of activations called neuronal avalanches, which reconfigure according to the task at hand and, hence, might constitute natural candidates to design brain-computer interfaces (BCI). To test this hypothesis, we used source-reconstructed magneto/electroencephalography, during resting state and a motor imagery task performed within a BCI protocol. To track the probability that an avalanche would spread across any two regions we built an avalanche transition matrix (ATM) and demonstrated that the edges whose transition probabilities significantly differed between conditions hinged selectively on premotor regions in all subjects. Furthermore, we showed that the topology of the ATMs allows task-decoding above the current gold standard. Hence, our results suggest that Neuronal Avalanches might capture interpretable differences between tasks that can be used to inform braincomputer interfaces.
Paper_EditorVersion.pdf (3.89 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-04345847 , version 1 (14-12-2023)
hal-04345847 , version 2 (27-01-2024)
Paternité
Marie-Constance Corsi, Pierpaolo Sorrentino, Denis P Schwartz, Nathalie George, Leonardo L. Gollo, et al.. Measuring Neuronal Avalanches to inform Brain-Computer Interfaces. iScience, 2023, 27 (1), pp.108734. ⟨10.1016/j.isci.2023.108734⟩. ⟨hal-04345847v2⟩
87 Consultations
25 Téléchargements
