Convex ordering of solutions to one-dimensional SDEs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this paper, we are interested in the propagation of convexity by the strong solution to a one-dimensional Brownian stochastic differential equation with coefficients Lipschitz in the spatial variable uniformly in the time variable and in the convex ordering between the solutions of two such equations. We prove that while these properties hold without further assumptions for convex functions of the processes at one instant only, an assumption almost amounting to spatial convexity of the diffusion coefficient is needed for the extension to convex functions at two instants. Under this spatial convexity of the diffusion coefficients, the two properties even hold for convex functionals of the whole path. For directionally convex functionals, the spatial convexity of the diffusion coefficient is no longer needed. Our method of proof consists in first establishing the results for time discretization schemes of Euler type and then transferring them to their limiting Brownian diffusions. We thus exhibit approximations which avoid {\em convexity arbitrages} by preserving convexity propagation and comparison and can be computed by Monte Carlo simulation.
hal-04349619 , version 1 (18-12-2023)
Benjamin Jourdain, Gilles Pagès. Convex ordering of solutions to one-dimensional SDEs. 2023. ⟨hal-04349619⟩
11 Consultations
0 Téléchargements
