Exact solutions for signal propagation along an excitable transmission line - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E Année : 2024
A simple transmission line composed of pulse-coupled units is presented. The model captures the basic properties of excitable media with, in particular, the robust transmission of information via traveling wave solutions. For rectified linear units with a cutoff threshold, the model is exactly solvable and analytical results on propagation are presented. The ability to convey a non-trivial message is studied in detail.
SignalPropagation-v2.pdf (681.24 Ko) Télécharger le fichier
hal-04349848 , version 1 (18-12-2023)
Paternité
Arnaud Tonnelier. Exact solutions for signal propagation along an excitable transmission line. Physical Review E , 2024, 109, pp.014219. ⟨10.1103/PhysRevE.109.014219⟩. ⟨hal-04349848⟩
34 Consultations
22 Téléchargements
