A new adhesively bonded composite repair for offshore steel structures: strength assessment and fatigue - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Floating productions, storage and offloading (FPSO) units are subject to corrosion problems. The use of adhesively bonded FRP patches as a repair appears to be a particularly interesting solution. However, design strategies still need to be improved and validated to insure the robustness and, ultimately, confidence in this solution. Since 2018, Bureau Veritas leads a joint industrial project called Strength Bond Offshore which aims at defining such a design strategy. First, the patch designed during this project will be presented. Then, the experimental test campaign is detailed: manufacturing, monotonic tests in traction and bending. Finally, the results of the fatigue tests campaign are developed. Ongoing additional developments are under progress to better assess equivalent interfacial behaviors for an overall design strategy.
CICE_2023_paper_111.pdf (1.55 Mo) Télécharger le fichier
hal-04350830 , version 1 (18-12-2023)
Paternité
Quentin Sourisseau, Emilie Lepretre, Sylvain Chataigner, Xavier Chapeleau, Maxime Deydier, et al.. A new adhesively bonded composite repair for offshore steel structures: strength assessment and fatigue. CICE 2023 - 11th International Conference on Fiber-Reinforced Polymer (FRP) Composites in Civil Engineering, Jul 2023, Rio de Janeiro, Brazil. pp.1-11, ⟨10.5281/zenodo.8136454⟩. ⟨hal-04350830⟩
27 Consultations
18 Téléchargements
