ReVISOR: ResUNets with visibility and intensity for structured outlier removal
Laser acquisition of large-scale point clouds is prone to several categories of measurement errors, which can lead, in particular, to the presence of undesirable outlier points. Existing outlier detection techniques are primarily based on analyzing local properties of point distributions to distinguish ''clean'' from ''noisy'' data. In contrast, real-world acquisition often has to deal with reflective surfaces, which can give rise to structured outliers that can be indistinguishable from clean geometry through purely local analysis. We make several contributions to address the problem of reflection-induced outlier detection. First, to overcome the scarcity of annotated data, we introduce a new dataset tailored for this task. Second, to capture non-local dependencies, we study and demonstrate, for the first time, the utility of deep learning based semantic segmentation architectures for reflection-induced outlier detection. By doing so, we bring together the fields of shape denoising/repair and semantic segmentation. Third, we demonstrate that additional non-local cues in the form of laser intensity and a computed visibility signal help boost the performance considerably. We denote our pipeline as ResUNets with Visibility and Intensity for Structured Outlier Removal, or ReVISOR, and demonstrate its superior performance against existing baselines on real-world data.
Apprentissage [cs.LG]
ReVISOR_ ResUNets with visibility and intensity for structured outlier removal (2).pdf (11.48 Mo)
Télécharger le fichier
