Non-Linear Reduced Modeling by Generalized Kernel-Based Dynamic Mode Decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Reduced modeling of a computationally demanding dynamical system aims at approximating its trajectories, while optimizing the trade-off between accuracy and computational complexity. In this work, we propose to achieve such an approximation by first embedding the trajectories in a reproducing kernel Hilbert space (RKHS), which exhibits appealing approximation and computational capabilities, and then solving the associated reduced model problem. More specifically, we propose a new efficient algorithm for data-driven reduced modeling of non-linear dynamics based on linear approximations in a RKHS. This algorithm takes advantage of the closed-form solution of a low-rank constraint optimization problem while exploiting advantageously kernel-based computations. Reduced modeling with this algorithm reveals a gain in approximation accuracy, as shown by numerical simulations, and in complexity with respect to existing approaches.
hal-04354110 , version 1 (19-12-2023)
Paternité
Patrick Héas, Cédric Herzet, Benoit Combès. Non-Linear Reduced Modeling by Generalized Kernel-Based Dynamic Mode Decomposition. 2023. ⟨hal-04354110⟩
21 Consultations
0 Téléchargements
