When proximal-point algorithms meet set-valued systems. An Optimization point of view of discrete-time sliding modes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This article is largely concerned with the relationships between the implicit (backward) discretization of set-valued sliding-mode systems (for control, state observation, or differentiation), and proximal-point algorithms of optimization. It is shown that using well-known notions like maximal monotonicity, proximal and resolvent operators, and Yosida approximations, it is possible to embed implicit time-discretization methods into the unified framework of proximal-point algorithms. This is illustrated with first-order and higher-order sliding-mode systems. Passivity is shown to play an important role. Robust, time-varying, Hamiltonian and high-order extensions of the classical proximal-point algorithm are introduced. Particular attention is given to the use of splitting methods to resolve computational issues related to implementation.
Automatique
Tutorial_Rapport.pdf (687.86 Ko) Télécharger le fichier
hal-04362282 , version 1 (22-12-2023)
Paternité
  • HAL Id : hal-04362282 , version 1
Félix Miranda-Villatoro, Fernando Castaños, Bernard Brogliato. When proximal-point algorithms meet set-valued systems. An Optimization point of view of discrete-time sliding modes. 2023. ⟨hal-04362282⟩
108 Consultations
114 Téléchargements
