Synchronized Deliveries with a Bike and a Self-Driving Robot - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Transportation Science Année : 2023
Yanlu Zhao
  • Fonction : Auteur
  • PersonId : 1329760
Ningxuan Kang
  • Fonction : Auteur
  • PersonId : 1329761
Online e-commerce giants are continuously investigating innovative ways to improve their practices in last-mile deliveries. Inspired by the current practices at JD.com (the largest online retailer by revenue in China), we investigate a delivery problem that we call the traveling salesman problem with bike and robot (TSPBR), where a cargo bike is aided by a self-driving robot to deliver parcels to customers in urban areas. We present two mixed-integer linear programming models and describe a set of valid inequalities to strengthen their linear relaxation. We show that these models can yield optimal solutions of TSPBR instances with up to 60 nodes. To efficiently find heuristic solutions, we also present a genetic algorithm based on a dynamic programming recursion that efficiently explores large neighborhoods. We computationally assess this genetic algorithm on instances provided by JD.com and show that high-quality solutions can be found in a few minutes of computing time. Finally, we provide some managerial insights to assess the impact of deploying the bike-and-robot tandem to deliver parcels in the TSPBR setting.
2023_Zhao_Synchronized deliveries with a bike and a self driving robot.pdf (6.72 Mo) Télécharger le fichier
hal-04362883 , version 1 (23-12-2023)
Yanlu Zhao, Diego Cattaruzza, Ningxuan Kang, Roberto Roberti. Synchronized Deliveries with a Bike and a Self-Driving Robot. Transportation Science, In press, ⟨10.1287/trsc.2023.0169⟩. ⟨hal-04362883⟩
25 Consultations
15 Téléchargements
