Impact of B0 field imperfections correction on BOLD sensitivity in 3D‐SPARKLING fMRI data
Purpose:
Static and dynamic field imperfections are detrimental to functional MRI (fMRI) applications, especially at ultra‐high magnetic fields (UHF). In this work, a field camera is used to assess the benefits of retrospectively correcting field perturbations on Blood Oxygen Level Dependent (BOLD) sensitivity in non‐Cartesian three‐dimensional (3D)‐SPARKLING fMRI acquisitions.
Methods:
fMRI data were acquired at 1 mm and for a 2.4s‐TR while concurrently monitoring in real‐time field perturbations using a Skope Clip‐on field camera in a novel experimental setting involving a shorter TR than the required minimal TR of the field probes. Measurements of the dynamic field deviations were used along with a static map to retrospectively correct static and dynamic field imperfections, respectively. In order to evaluate the impact of such a correction on fMRI volumes, a comparative study was conducted on healthy volunteers.
Results:
Correction of deviations improved image quality and yielded between 20% and 30% increase in median temporal signal‐to‐noise ratio (tSNR). Using fMRI data collected during a retinotopic mapping experiment, we demonstrated a significant increase in sensitivity to the BOLD contrast and improved accuracy of the BOLD phase maps: 44% (resp., 159%) more activated voxels were retrieved when using a significance control level based on a p‐value of 0.001 without correcting for multiple comparisons (resp., 0.05 with a false discovery rate correction). Conclusion 3D‐SPARKLING fMRI hugely benefits from static and dynamic imperfections correction. However, the proposed experimental protocol is flexible enough to be deployed on a large spectrum of encoding schemes, including arbitrary non‐Cartesian readouts.
Sciences de l'ingénieur [physics]
Main Document.pdf (338.86 Ko)
Télécharger le fichier
Supplementary Materials.pdf (1.16 Mo)
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
