A general martingale approach to large noise homogenization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We consider Markov processes with generator of the form $γ\mathcal{L}_{1} + \mathcal{L}_{0}$, in which $\mathcal{L}_{1}$ generates a so-called dominant process that converges at large times towards a random point in a fixed subset called the effective state space. Using the usual characterization through martingales problems, we give general conditions under which homogenization holds true: the original process converges, when $γ$ is large and for the Meyer-Zheng pseudo-path topology and for finite-dimensional time marginals, towards an identified effective Markov process on the effective space. Few simple model examples for diffusions are studied.
main.pdf (480.24 Ko) Télécharger le fichier
hal-04363393 , version 1 (24-12-2023)
Paternité
Dimitri Faure, Mathias Rousset. A general martingale approach to large noise homogenization. 2023. ⟨hal-04363393⟩
19 Consultations
11 Téléchargements
