A General Framework for Enumerating Equivalence Classes of Solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithmica Année : 2023
When a problem has more than one solution, it is often important, depending on the underlying context, to enumerate (i.e., to list) them all. Even when the enumeration can be done in polynomial delay, that is, spending no more than polynomial time to go from one solution to the next, this can be costly as the number of solutions themselves may be huge, including sometimes exponential. Furthermore, depending on the application, many of these solutions can be considered equivalent. The problem of an efficient enumeration of the equivalence classes or of one representative per class (without generating all the solutions), although identified as a need in many areas, has been addressed only for very few specific cases. In this paper, we provide a general framework that solves this problem in polynomial delay for a wide variety of contexts, including optimization ones that can be addressed by dynamic programming algorithms, and for certain types of equivalence relations between solutions.
Wang2023.pdf (505.74 Ko) Télécharger le fichier
hal-04365403 , version 1 (28-12-2023)
Paternité
Yishu Wang, Arnaud Mary, Marie-France Sagot, Blerina Sinaimeri. A General Framework for Enumerating Equivalence Classes of Solutions. Algorithmica, 2023, 85 (10), pp.3003-3023. ⟨10.1007/s00453-023-01131-1⟩. ⟨hal-04365403⟩
37 Consultations
4 Téléchargements
