Traffic Control via Fleets of Connected and Automated Vehicles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
The foreseen deployment of Connected and Automated Vehicles (CAVs) on public roads opens the perspective of reducing the social and environmental impacts of traffic congestion using CAVs as optimal control actuators, operating as moving bottlenecks on the surrounding flow. In this paper, we propose three control strategies, based on different levels of cooperation, to improve density dependent traffic performance indexes, such as fuel consumption. We rely on a multi-scale approach to model mixed traffic composed of a small fleet of CAVs in the bulk flow. In particular, CAVs are allowed to overtake (if on distinct lanes) or queuing (if on the same lane). Controlling CAVs desired speeds allows to act on the system to minimize the selected cost function. For the proposed control strategies, we apply both global optimization and a Model Predictive Control approach. In particular, we perform numerical tests to investigate how the CAVs number and positions impacts the result, showing that few, optimally chosen vehicles are sufficient to significantly improve the selected performance indexes, even using a decentralized control policy. Simulation results support the attractive perspective of exploiting a very small number of vehicles as endogenous control actuators to regulate traffic flow on road networks, providing a flexible alternative to traditional control methods. Moreover, we compare the impact of the proposed control strategies (decentralized, quasi-decentralized, centralized). “This work has been submitted to the IEEE for possible publication. Copyright may be transferred without notice, after which this version may no longer be accessible.”
CAVhal.pdf (5.12 Mo) Télécharger le fichier
hal-04366870 , version 1 (29-12-2023)
  • HAL Id : hal-04366870 , version 1
Chiara Daini, Maria Laura Delle Monache, Paola Goatin, Antonella Ferrara. Traffic Control via Fleets of Connected and Automated Vehicles. 2023. ⟨hal-04366870⟩
66 Consultations
51 Téléchargements
