Results of the Ontology Alignment Evaluation Initiative 2023 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mina Abd Nikooie Pour
  • Fonction : Auteur
  • PersonId : 1323337
Leyla Jael Castro
Jiaoyan Chen
Hang Dong
Sven Hertling
Yuan He
  • Fonction : Auteur
  • PersonId : 1227563
Dr Sarika Jain
  • Fonction : Auteur
  • PersonId : 1053500
Naouel Karam
  • Fonction : Auteur
  • PersonId : 1323359
Patrick Lambrix
Huanyu Li
Ying Li
  • Fonction : Auteur
  • PersonId : 1323342
Heiko Paulheim
Catia Pesquita
Pavel Shvaiko
  • Fonction : Auteur
  • PersonId : 1323368
Mingfang Wu
  • Fonction : Auteur
  • PersonId : 1229593
Beyza Yaman
Lu Zhou
  • Fonction : Auteur
The Ontology Alignment Evaluation Initiative (OAEI) aims at comparing ontology matching systems on precisely defined test cases. These test cases can be based on ontologies of different levels of complexity and use different evaluation modalities. The OAEI 2023 campaign offered 15 tracks and was attended by 16 participants. This paper is an overall presentation of that campaign.
oaei23_paper0.pdf (731.01 Ko) Télécharger le fichier
hal-04366893 , version 1 (29-12-2023)
Paternité
  • HAL Id : hal-04366893 , version 1
Mina Abd Nikooie Pour, Alsayed Algergawy, Patrice Buche, Leyla Jael Castro, Jiaoyan Chen, et al.. Results of the Ontology Alignment Evaluation Initiative 2023. 18th International Workshop on Ontology Matching (OM 2023), Nov 2023, Athens, Greece. pp.97--139. ⟨hal-04366893⟩
179 Consultations
35 Téléchargements
