A GRASP-based algorithm for Virtual Network Embedding - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
With the rise of network virtualization, network slicing is becoming a hot research topic. Indeed, network operators must deal with capacity-limited resources while insuring an extreme availability of services. Several approaches exist in the literature to tackle such a problem, some of them converge quickly to a local minimum, while others are not explainable and therefore do not provide the necessary guarantees for their deployment in a real network. In this context, we propose a new approach for Virtual Network Embedding (VNE) based on the Greedy Adaptive Search Procedure (GRASP). Using the GRASP meta-heuristic ensures the robustness of the solution to changing constraints and environments. Moreover, the proposed realistic approach allows a more efficient and directed exploration of the solution space, in opposition to existing techniques. The simulation results show the potential of the proposed method for solving services' placement problems and its superiority over existing approaches.
Papier_Amine.pdf (147.99 Ko) Télécharger le fichier
hal-04368546 , version 1 (01-01-2024)
Paternité
Amine Rguez, Yassine Hadjadj-Aoul, Farah Slim, Gerardo Rubino, Asma Selmi. A GRASP-based algorithm for Virtual Network Embedding. ISCC 2023 - IEEE Symposium on Computers and Communications, Jul 2023, Gammarth, Tunisia. pp.470-473, ⟨10.1109/ISCC58397.2023.10218024⟩. ⟨hal-04368546⟩
8 Consultations
14 Téléchargements
