Joint Learning of Fully Connected Network Models in Lifting Based Image Coders
The optimization of prediction and update operators
plays a prominent role in lifting-based image coding schemes. In
this paper, we focus on learning the prediction and update models
involved in a recent Fully Connected Neural Network (FCNN)-
based lifting structure. While a straightforward approach consists
in separately learning the different FCNN models by optimizing
appropriate loss functions, jointly learning those models is a
more challenging problem. To address this problem, we first
consider a statistical model-based entropy loss function that yields
a good approximation to the coding rate. Then, we develop a
multi-scale optimization technique to learn all the FCNN models
simultaneously. For this purpose, two loss functions defined across
the different resolution levels of the proposed representation
are investigated. While the first function combines standard
prediction and update loss functions, the second one aims to
obtain a good approximation to the rate-distortion criterion.
Experimental results carried out on two standard image datasets,
show the benefits of the proposed approaches in the context of
lossy and lossless compression.
TIP2023_Joint_Learning_of_FCNN_in_Lifting_Based_Image_Coders.pdf (3.65 Mo)
Télécharger le fichier
