A Novel Integer Linear Programming Approach for Global L0 Minimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Machine Learning Research Année : 2023
Diego Delle Donne
  • Fonction : Auteur
  • PersonId : 1118880
Matthieu Kowalski
Given a vector y ∈ R n and a matrix H ∈ R n×m , the sparse approximation problem P 0/p asks for a point x such that ∥y-Hx∥ p ≤ α, for a given scalar α, minimizing the size of the support ∥x∥ 0 := #{j | x j ̸ = 0}. Existing convex mixed-integer programming formulations for P 0/p are of a kind referred to as "big-M ", meaning that they involve the use of a bound M on the values of x. When a proper value for M is not known beforehand, these formulations are not exact, in the sense that they may fail to recover the wanted global minimizer. In this work, we study the polytopes arising from these formulations and derive valid inequalities for them. We first use these inequalities to design a branch-and-cut algorithm for these models. Additionally, we prove that these inequalities are sufficient to describe the set of feasible supports for P 0/p. Based on this result, we introduce a new (and the first to our knowledge) M-independent integer linear programming formulation for P 0/p , which guarantees the recovery of the global minimizer. We propose a practical approach to tackle this formulation, which has exponentially many constraints. The proposed methods are then compared in computational experimentation to test their potential practical contribution.
setcov_paper_final.pdf (465.85 Ko) Télécharger le fichier
hal-04372309 , version 1 (04-01-2024)
  • HAL Id : hal-04372309 , version 1
Diego Delle Donne, Matthieu Kowalski, Leo Liberti. A Novel Integer Linear Programming Approach for Global L0 Minimization. Journal of Machine Learning Research, inPress. ⟨hal-04372309⟩
126 Consultations
158 Téléchargements
