Analytical Model for Performance Evaluation of Token-Passing Based WiNoCs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recent advances in technology integration have introduced new on-chip interconnects, such as wireless Network-on- Chips (NoCs), making the design space too large to be efficiently explored with time-consuming standard simulators. In this paper, we propose an analytical model based on queuing theory to evaluate the latency of manycore architecture interconnects. We consider a hybrid interconnection that utilizes electrical and wireless NoCs for both intra- and inter-cluster communications. The results demonstrate that our proposed model significantly reduces the simulation execution time by up to 500× while maintaining an error rate of less than 5% compared to the Noxim cycle-accurate simulator.
NOCS_Paper_Analytical_Final.pdf (1.37 Mo) Télécharger le fichier
hal-04373591 , version 1 (15-01-2024)
Paternité
  • HAL Id : hal-04373591 , version 1
Ibrahim Krayem, Joel Ortiz Sosa, Cédric Killian, Daniel Chillet. Analytical Model for Performance Evaluation of Token-Passing Based WiNoCs. NOCS 2023 - 17th IEEE/ACM International Symposium on Networks‑on‑Chip, Sep 2023, Hamburg, Germany. pp.1-9. ⟨hal-04373591⟩
33 Consultations
15 Téléchargements
