DINOv2: Learning Robust Visual Features without Supervision - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Preprints, Working Papers, ... Year : 2023
Maxime Oquab
  • Function : Author
Huy Vo
  • Function : Author
Marc Szafraniec
  • Function : Author
Vasil Khalidov
  • Function : Author
Daniel Haziza
  • Function : Author
Francisco Massa
  • Function : Author
Alaaeldin El-Nouby
  • Function : Author
Mahmoud Assran
  • Function : Author
Nicolas Ballas
  • Function : Author
Wojciech Galuba
  • Function : Author
Russell Howes
  • Function : Author
Po-Yao Huang
  • Function : Author
Shang-Wen Li
  • Function : Author
Ishan Misra
  • Function : Author
Michael Rabbat
  • Function : Author
Vasu Sharma
  • Function : Author
Gabriel Synnaeve
  • Function : Author
Hu Xu
  • Function : Author
Hervé Jegou
  • Function : Author
Patrick Labatut
  • Function : Author
Armand Joulin
  • Function : Author
Piotr Bojanowski
  • Function : Author
The recent breakthroughs in natural language processing for model pretraining on large quantities of data have opened the way for similar foundation models in computer vision. These models could greatly simplify the use of images in any system by producing all-purpose visual features, i.e., features that work across image distributions and tasks without finetuning. This work shows that existing pretraining methods, especially self-supervised methods, can produce such features if trained on enough curated data from diverse sources. We revisit existing approaches and combine different techniques to scale our pretraining in terms of data and model size. Most of the technical contributions aim at accelerating and stabilizing the training at scale. In terms of data, we propose an automatic pipeline to build a dedicated, diverse, and curated image dataset instead of uncurated data, as typically done in the self-supervised literature. In terms of models, we train a ViT model (Dosovitskiy et al., 2020) with 1B parameters and distill it into a series of smaller models that surpass the best available all-purpose features, OpenCLIP (Ilharco et al., 2021) on most of the benchmarks at image and pixel levels.
CVPR_2023_dinov2 (4).pdf (7.31 Mo) Télécharger le fichier
Dates and versions
hal-04376640 , version 1 (06-01-2024)
hal-04376640 , version 2 (02-02-2024)
Attribution
Identifiers
Cite
Maxime Oquab, Timothée Darcet, Théo Moutakanni, Huy Vo, Marc Szafraniec, et al.. DINOv2: Learning Robust Visual Features without Supervision. 2024. ⟨hal-04376640v2⟩
117 View
68 Download
Share
