Marginal MAP estimation of a Bernoulli-Gaussian signal: continuous relaxation approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We focus on recovering the support of sparse signals for sparse inverse problems. Using a Bernoulli-Gaussian prior to model sparsity, we propose to estimate the support of the sparse signal using the so-called Marginal Maximum a Posteriori estimate after marginalizing out the values of the nonzero coefficients. To this end, we propose an Expectation-Maximization procedure in which the discrete optimization problem in the M-step is relaxed into a continuous problem. Empirical assessment with simulated Bernoulli-Gaussian data using magnetoencephalographic lead field matrix shows that this approach outperforms the usual l0 Joint Maximum a Posteriori estimation in Type-I and Type-II error for support recovery, as well as in SNR for signal estimation.
Barbault23.pdf (319.33 Ko) Télécharger le fichier
hal-04383978 , version 1 (10-01-2024)
  • HAL Id : hal-04383978 , version 1
Pierre Barbault, Matthieu Kowalski, Charles Soussen. Marginal MAP estimation of a Bernoulli-Gaussian signal: continuous relaxation approach. EUSIPCO 2023 - the 31st European Signal Processing Conference, Sep 2023, Helsinki, Finland. pp.1833-1837. ⟨hal-04383978⟩
29 Consultations
17 Téléchargements
