GIRAFF: Reverse Auction-based Placement for Fog Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
GIRAFF: Enchères Inversées pour le Placement de Fonctions dans le Fog
GIRAFF
Function-as-a-Service (FaaS) is a compelling new programming model for developing applications running on fog infrastructures. FaaS applications are composed of short-lived, event-triggered units, called functions. Functions can be flexibly deployed on demand along the cloud-to-thing continuum. However, deciding how to place those functions in the fog presents multiple challenges. The fog contains diverse, geo-distributed, and potentially resource-constrained nodes that should be efficiently shared between applications with latency requirements. Importantly, fog nodes are owned by different entities that should be incentivized to share their resources. Most function placement approaches ignore latency requirements or the presence of multiple owners in fog infrastructures. To address these challenges, this article proposes a marketbased approach to place FaaS applications in the fog. Clients submit function placement requests associated with SLAs that specify expected guarantees over network latency and allocated resources. The approach then organizes an auction among fog node providers to determine the nodes that host each function and the revenue of the provider. The article presents an open-source implementation of the approach evaluated on the Grid'5000 testbed. Experiments demonstrate that our approach can reduce client spending by up to three times while delivering service quality that matches or exceeds that of baseline methods. CCS CONCEPTS • Computer systems organization → Distributed architectures.
GIR.pdf (257.88 Ko) Télécharger le fichier
hal-04384516 , version 1 (11-01-2024)
Copyright (Tous droits réservés)
Volodia Parol-Guarino, Nikos Parlavantzas. GIRAFF: Reverse Auction-based Placement for Fog Functions. WoSC 2023 - 9th International Workshop on Serverless Computing, Dec 2023, Bologna, Italy. pp.53-58, ⟨10.1145/3631295.3631402⟩. ⟨hal-04384516⟩
44 Consultations
18 Téléchargements
