Graph-based multi-layer querying in Parseme Corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bruno Guillaume
We present a graph-based tool which can be used to explore Verbal Multi-Word Expression (VMWE) annotated in the Parseme project. The tool can be used for linguistic exploration on the data, for helping the manual annotation process and to search for errors or inconsistencies in the annotations.
2023.mwe-1.9.pdf (476.8 Ko) Télécharger le fichier
hal-04387852 , version 1 (11-01-2024)
Paternité
Bruno Guillaume. Graph-based multi-layer querying in Parseme Corpora. Proceedings of the 19th Workshop on Multiword Expressions (MWE 2023), Jun 2023, Dubrovnic, Croatia. pp.58-64, ⟨10.18653/v1/2023.mwe-1.9⟩. ⟨hal-04387852⟩
18 Consultations
8 Téléchargements
