Infrastructure adaptation and emergence of loops in network routing with time-dependent loads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review E Année : 2023
Network routing approaches are widely used to study the evolution in time of self-adapting systems. However, few advances have been made for problems where adaptation is governed by time-dependent inputs. In this work we study a dynamical system where the edge conductivities of a network are regulated by time-varying mass loads injected on nodes. Motivated by empirical observations, we assume that conductivities adapt slowly with respect to the characteristic time of the loads. Furthermore, assuming the loads to be periodic, we derive a dynamics where the evolution of the system is controlled by a matrix obtained with the Fourier coefficients of the input loads. Remarkably, we find a sufficient condition on these coefficients that determines when the resulting network topologies are trees. We show an example of this on the Bordeaux bus network where we tune the input loads to interpolate between loopy and tree topologies. We validate our model on several synthetic networks and provide an expression for long-time solutions of the original conductivities.
hal-04388631 , version 1 (11-01-2024)
Alessandro Lonardi, Enrico Facca, Mario Putti, Caterina de Bacco. Infrastructure adaptation and emergence of loops in network routing with time-dependent loads. Physical Review E , 2023, 107 (2), pp.024302. ⟨10.1103/PhysRevE.107.024302⟩. ⟨hal-04388631⟩
8 Consultations
0 Téléchargements
