On stability of second-order nonlinear time-delay systems without damping - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alexander Aleksandrov
Emilia Fridman
  • Fonction : Auteur
  • PersonId : 838164
For a second-order system with time delays and power nonlinearity of the degree higher than one, which does not contain a velocity-proportional damping term, the conditions of local asymptotic stability of the zero solution are proposed. The result is based on application of the Lyapunov-Razumikhin approach, and it is illustrated by simulations. Our local stability conditions for nonlinear systems are less restrictive than stability conditions of the corresponding linear models.
Automatique
dom-3.pdf (426.8 Ko) Télécharger le fichier
hal-04390334 , version 1 (12-01-2024)
Paternité
  • HAL Id : hal-04390334 , version 1
Alexander Aleksandrov, Denis Efimov, Emilia Fridman. On stability of second-order nonlinear time-delay systems without damping. CDC 2023 - 62nd IEEE Conference on Decision and Control, Dec 2023, Singapore, Singapore. ⟨hal-04390334⟩
22 Consultations
24 Téléchargements
