On Generalized Homogeneous Leader-following Consensus Control for Multi-agent Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Control of Network Systems Année : 2024
In this paper, the leader-following consensus problem for multi-agent systems is considered. Each agent is assumed to be modeled by a linear multi-input system. A novel (generalized homogeneous) consensus control protocol is designed under the assumption that there are some uncertainties in the dynamic of the leader. Some conditions (LMIs) are derived to select the control parameters in order to ensure the input-to-state stability and global finite-time stability of the consensus errors with desired homogeneity degrees. Some simulations are performed to illustrate the obtained results.
generic-color.pdf (2.43 Mo) Télécharger le fichier
hal-04390600 , version 1 (12-01-2024)
Min Li, Andrey Polyakov, Gang Zheng. On Generalized Homogeneous Leader-following Consensus Control for Multi-agent Systems. IEEE Transactions on Control of Network Systems, In press, ⟨10.1109/TCNS.2023.3290429⟩. ⟨hal-04390600⟩
45 Consultations
20 Téléchargements
