Fixed-time Stabilization with a Prescribed Constant Settling Time by Static Feedback for Delay-Free and Input Delay Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Robust and Nonlinear Control Année : 2024
A static non-linear homogeneous feedback for a fixed-time stabilization of a linear time-invariant (LTI) system is designed in such a way that the settling time is assigned exactly to a prescribed constant for all nonzero initial conditions. The constant convergence time is achieved due to a dependence of the feedback gain of the initial state of the system. The robustness of the closed-loop system with respect to measurement noise and exogenous perturbations is studied using the concept of Input-to-State Stability (ISS). Both delay-free and input delay systems are considered. Theoretical results are illustrated by numerical simulations.
Safety_hom-5.pdf (474.28 Ko) Télécharger le fichier
hal-04390695 , version 1 (12-01-2024)
  • HAL Id : hal-04390695 , version 1
Andrey Polyakov, Miroslav Krstic. Fixed-time Stabilization with a Prescribed Constant Settling Time by Static Feedback for Delay-Free and Input Delay Systems. International Journal of Robust and Nonlinear Control, In press. ⟨hal-04390695⟩
8 Consultations
9 Téléchargements
