Lyapunov-based Consistent Discretization of Quasi-Continuous High Order Sliding Modes
In this chapter we propose an explicit discretization scheme for class of disturbed systems controlled by homogeneous quasi-continuous High Order Sliding Mode controllers which are equipped with a homogeneous Lyapunov function. Such a Lyapunov function is used to construct the discretization scheme that preserves important features from the original continuous-time system: asymptotic stability, finite-time convergence, and the Lyapunov function itself.
Automatique
