Stationary Bragg reflection of laser light in inhomogeneous absorbing plasmas inside inertial confinement fusion Hohlraums - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physics of Plasmas Année : 2023
M. Vandenboomgaerde
M. Casanova
  • Fonction : Auteur
F. Chaland
M. Bonnefille
A. Grisollet
L. Videau
S. Depierreux
V. Tassin
C. Courtois
H. Chen
Laser-produced plasma in inertial confinement fusion (ICF) Hohlraums are marked with density non-uniformity whose length scale can go down to micrometers. This scale is of the order of the laser wavelength. The WKB approximation, which is classically used in radiation-hydrodynamic codes to compute the laser trajectory, cannot correctly take into account such small-scale inhomogeneity of the plasma. Going beyond this approximation, we predict a novel mechanism for the laser reflection. We show that an electromagnetic plane wave with wave number k resonates with the kB=2 k Fourier component of a multimode perturbation of the background density and generates a reflected wave. It is the first time that this reflection is considered for stationary inhomogeneous ICF plasmas, and the energy absorption is taken into account. This mechanism, which is a form of Bragg reflection, can occur away from the critical surface and generate a drift of the location of the laser absorption. Furthermore, this absorption will be periodically modulated with a kB wave number. The stationary Bragg reflection can explain ongoing discrepancies between experimental and numerical data about laser trajectory and absorption in ICF Hohlraums.
hal-04392295 , version 1 (13-01-2024)
M. Vandenboomgaerde, M. Casanova, F. Chaland, M. Bonnefille, A. Grisollet, et al.. Stationary Bragg reflection of laser light in inhomogeneous absorbing plasmas inside inertial confinement fusion Hohlraums. Physics of Plasmas, 2023, 30 (12), pp.122702. ⟨10.1063/5.0170189⟩. ⟨hal-04392295⟩
14 Consultations
0 Téléchargements
