Technical report: Impact of User Privacy and Mobility on Edge Offloading - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Offloading high-demanding applications to the edge provides better quality of experience (QoE) for users with limited hardware devices. However, to maintain a competitive QoE, infrastructure, and service providers must adapt to users' different mobility patterns, which can be challenging, especially for location-based services (LBS). Another issue that needs to be tackled is the increasing demand for user privacy protection. With less (accurate) information regarding user location, preferences, and usage patterns, forecasting the performance of offloading mechanisms becomes even more challenging. This work discusses the impacts of users' privacy and mobility when offloading to the edge. Different privacy and mobility scenarios are simulated and discussed to shed light on the trade-offs (e.g., privacy protection at the cost of increased latency) among privacy protection, mobility, and offloading performance.
PIMRC_2023_HAL.pdf (1.22 Mo) Télécharger le fichier
hal-04393564 , version 1 (15-01-2024)
Domaine public
João Paulo Esper, Nadjib Achir, Kleber Vieira Cardoso, Jussara Almeida. Technical report: Impact of User Privacy and Mobility on Edge Offloading. 2024. ⟨hal-04393564⟩
16 Consultations
16 Téléchargements
