Analyzing and Optimizing Extended-CAM Service Using Simple Stochastic Geometry Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Vehicular Ad hoc Networks (VANETs) offer a promising approach to enhancing road safety. Cooperative Awareness Messages (CAM) is an essential service in VANETs, allowing vehicles to transmit radio beacons containing their positions and velocities. These messages inform nearby vehicles about the traffic situation. This paper focuses on Extended Cooperative Awareness Messages (ECAM), which include additional information about nearby vehicles. ECAM beacons consist of a vehicle's speed, position, and data on the positions and velocities of other vehicles in its vicinity. This comprehensive information enables nearby vehicles to understand the traffic situation and take appropriate actions to prevent potential collisions. Studies demonstrate that ECAM has the potential to significantly improve road safety by providing comprehensive and up-todate traffic information. This paper uses stochastic geometry to evaluate different versions of ECAM services and compare the results with simple simulations. The evaluation assumes random vehicle placement using a homogeneous Poisson Point Process and models the ECAM service using the Matern Point Process.
A_simple_model_for_ECAM-4.pdf (399.38 Ko) Télécharger le fichier
hal-04393587 , version 1 (15-01-2024)
Copyright (Tous droits réservés)
Paul Mühlethaler, Nadjib Achir. Analyzing and Optimizing Extended-CAM Service Using Simple Stochastic Geometry Model. PEMWN 2023 - 12th IFIP/IEEE International Conference on Performance Evaluation and Modeling in Wired and Wireless Networks, Sep 2023, Berlin, Germany. pp.1-6, ⟨10.23919/PEMWN58813.2023.10304925⟩. ⟨hal-04393587⟩
37 Consultations
22 Téléchargements
