Decentralized Partially Observable Markov Decision Process for Power Grid Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
Processus de Décision de Markov Décentralisé et Partiellement Observable pour la Gestion du Réseau Electrique
Following the energy transition, Réseau de Transport d' Electricité (RTE) - the French Transport System Operator- is developing new adaptive zonal automatons. Each automaton monitors a zone of the power grid thanks to an optimization algorithm. An automaton can act on the power grid configuration in case of constraints. Each automaton can receive a target setpoint from human operators to decide the appropriate actions. Examples of a target path include (un)desirable configurations in future hours or information about other zones. To make operators’ work easier, RTE needs a decision-support assistant to recommend relevant target setpoints. Reinforcement Learning (RL) is a promising method to elaborate such target setpoints. However, RL requires a high number of training iterations which is time-consuming. In this poster, we present our research to emulate an automaton with a short response time, thanks to a RL approach, to afford a sufficient number of iterations and reasonable computation times during training.
RL_Summer_School_2023___Poster.pdf (1.26 Mo) Télécharger le fichier
Licence : CC BY ND - Paternité - Pas de modifications
hal-04396121 , version 1 (15-01-2024)
  • HAL Id : hal-04396121 , version 1
Eva Boguslawski, Alessandro Leite, Marc Schoenauer, Matthieu Dussartre, Benjamin Donnot. Decentralized Partially Observable Markov Decision Process for Power Grid Management. Reinforcement Learning Summer School 2023, Jun 2023, Barcelone, Spain. . ⟨hal-04396121⟩
22 Consultations
8 Téléchargements
