Better than RECIST and Faster than iRECIST: Defining the Immunotherapy Progression Decision Score to Better Manage Progressive Tumors on Immunotherapy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Clinical Cancer Research Année : 2023
Nathalie Lassau
  • Fonction : Auteur
Littisha Lawrance
Siham Farhane
Rahma Feki-Mkaouar
Joya Hadchiti
  • Fonction : Auteur
Lama Dawi
Julien Vibert
Clara Cousteix
Camille Mazza
Michele Kind
Antoine Italiano
Aurelien Marabelle
Samy Ammari
Stephane Champiat
Abstract Purpose: The objective of the study is to propose the immunotherapy progression decision (iPD) score, a practical tool based on patient features that are available at the first evaluation of immunotherapy treatment, to help oncologists decide whether to continue the treatment or switch rapidly to another therapeutic line when facing a progressive disease patient at the first evaluation. Experimental Design: This retrospective study included 107 patients with progressive disease at first evaluation according to RECIST 1.1. Clinical, radiological, and biological data at baseline and first evaluation were analyzed. An external validation set consisting of 31 patients with similar baseline characteristics was used for the validation of the score. Results: Variables were analyzed in a univariate study. The iPD score was constructed using only independent variables, each considered as a worsening factor for the survival of patients. The patients were stratified in three groups: good prognosis (GP), poor prognosis (PP), and critical prognosis (CP). Each group showed significantly different survivals (GP: 11.4, PP: 4.4, CP: 2.3 months median overall survival, P < 0.001, log-rank test). Moreover, the iPD score was able to detect the pseudoprogressors better than other scores. On the validation set, CP patients had significantly worse survival than PP and GP patients (P < 0.05, log-rank test). Conclusions: The iPD score provides oncologists with a new evaluation, computable at first progression, to decide whether treatment should be continued (for the GP group), or immediately changed for the PP and CP groups. Further validation on larger cohorts is needed to prove its efficacy in clinical practice.
Fichier non déposé
hal-04396436 , version 1 (16-01-2024)
Younes Belkouchi, Hugues Talbot, Nathalie Lassau, Littisha Lawrance, Siham Farhane, et al.. Better than RECIST and Faster than iRECIST: Defining the Immunotherapy Progression Decision Score to Better Manage Progressive Tumors on Immunotherapy. Clinical Cancer Research, 2023, 29 (8), pp.1528-1534. ⟨10.1158/1078-0432.CCR-22-0890⟩. ⟨hal-04396436⟩
23 Consultations
0 Téléchargements
