Using convolutional dictionary learning to detect task-related neuromagnetic transients and ageing trends in a large open-access dataset - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2023
Human neuromagnetic activity is characterised by a complex combination of transient bursts with varying spatial and temporal characteristics. The characteristics of these transient bursts change during task performance and normal ageing in ways that can inform about underlying cortical sources. Many methods have been proposed to detect transient bursts, with the most successful ones being those that employ multi-channel, data-driven approaches to minimize bias in the detection procedure. There has been little research, however, into the application of these data-driven methods to large datasets for group-level analyses. In the current work, we apply a data-driven convolutional dictionary learning (CDL) approach to detect neuromagnetic transient bursts in a large group of healthy participants from the Cam-CAN dataset. CDL was used to extract repeating spatiotemporal motifs in 538 participants between the ages of 18-88 during a sensorimotor task. Motifs were then clustered across participants based on similarity, and relevant task-related clusters were analysed for age-related trends in their spatiotemporal characteristics. Seven task-related motifs resembling known transient burst types were identified through this analysis, including beta, mu, and alpha type bursts. All burst types showed positive trends in their activation levels with age that could be explained by increasing burst rate with age. This work validated the data-driven CDL approach for transient burst detection on a large dataset and identified robust information about the complex characteristics of human brain signals and how they change with age.
hal-04397451 , version 1 (16-01-2024)
Lindsey Power, Cédric Allain, Thomas Moreau, Alexandre Gramfort, Timothy Bardouille. Using convolutional dictionary learning to detect task-related neuromagnetic transients and ageing trends in a large open-access dataset. NeuroImage, 2023, 267, pp.119809. ⟨10.1016/j.neuroimage.2022.119809⟩. ⟨hal-04397451⟩
13 Consultations
0 Téléchargements
