Towards Formalization and Sharing of Atelier B Proofs with Dedukti - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
Atelier B is widely used to develop safe-by-construction programs. Numerous systems and pieces of software have been designed and built at the highest level of safety with this framework. But similar toolsets are used for the same purpose, and we advocate that they would all benefit from proof-exchange facilities. To this aim, we introduce an export tool of Atelier B proof obligations to Dedukti, a universal logical framework based on type theory, and designed for interoperability. We then describe a preliminary experimentation to reconstruct detailed demonstrations of those proof obligations, so that they can be doublechecked by Dedukti, and be ready for a later export to the other tools. We also discuss the methodologies and potential framework architectures that could be helpful in such a proof-exchange objective.
article.pdf (272.21 Ko) Télécharger le fichier
hal-04398119 , version 1 (16-01-2024)
  • HAL Id : hal-04398119 , version 1
Claude Stolze, Olivier Hermant, Romain Guillaumé. Towards Formalization and Sharing of Atelier B Proofs with Dedukti. 2024. ⟨hal-04398119⟩
33 Consultations
29 Téléchargements
