Plumes and large scale circulation in turbulent thermal convection with a rough plate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In a real thermal system, the underlying surfaces have specific topographies or small scale roughness that have a significant effect on heat transfer. In particular, in the case of turbulent convection, the addition of wall roughness leads to a global increase in heat transfer. Three successive heat transfer regimes can be obtained. It is generally accepted that the heat transfer enhancement results from an intensification of the thermal plume emission. In the present study, we consider convection over a regularly roughened plate in a Rayleigh-Bénard cell. The aim of this work is to determine how the roughness alters the interactions between theplumes and the large-scale circulation, as a function of the heat transfer regime. Three-dimensional direct numerical simulations (DNS) have been performed for Rayleigh numbers covering five decades up to Ra = 1010 and for two roughness sizes. However, even though the development of massively parallel DNS solvers now makes it possible to tackle calculations in highly turbulent regimes, it remains difficult to statistically approach all flow scales, store them or easily replay their sequences. Therefore, a first attempt to build a reduced model for 3D flow reconstruction using physically informed neural networks is presented. This work benefits from the French National Research Agency funding (THERMAL project).
Template_RBC23_Sergent.pdf (625.56 Ko) Télécharger le fichier
hal-04400263 , version 1 (22-01-2024)
  • HAL Id : hal-04400263 , version 1
Anne Sergent, Yann Fraigneau, Didier Lucor. Plumes and large scale circulation in turbulent thermal convection with a rough plate. RBC 2023 - 9th International Conference on Rayleigh-Bénard Turbulence, Oct 2023, Xi'an, China. ⟨hal-04400263⟩
22 Consultations
9 Téléchargements
