Surrogate modeling of time-domain electromagnetic wave propagation via dynamic mode decomposition and radial basis function
This work introduces an 'equation-free' non-intrusive model order reduction (NIMOR) method for surrogate modeling of time-domain electromagnetic wave propagation. The nested proper orthogonal decomposition (POD) method, as a prior dimensionality reduction technique, is employed to extract the time-and parameter-independent reduced basis (RB) functions from a collection of high-fidelity (HF) solutions (or snapshots) on a properly chosen training parameter set. A dynamic mode decomposition (DMD) method, resulting in a further dimension reduction of the NIMOR method, is then used to predict the reduced-order coefficient vectors for future time instants on the previous training parameter set. The radial basis function (RBF) is employed for approximating the reduced-order coefficient vectors at a given untrained parameter in the future time instants, leading to the applicability of DMD method to parameterized problems. A main advantage of the proposed method is the use of a multi-step procedure consisting of the POD, DMD and RBF techniques to accurately and quickly recover field solutions from a few large-scale simulations. Numerical experiments for the scattering of a plane wave by a dielectric disk, by a multi-layer disk, and by a 3-D dielectric sphere nicely illustrate the performance of the NIMOR method.
