Data Mining‐Based Techniques for Software Fault Localization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
This chapter illustrates the basic concepts of fault localization using a data mining technique. It utilizes the Trityp program to illustrate the general method. Formal concept analysis and association rule are two well‐known methods for symbolic data mining. In their original inception, they both consider data in the form of an object‐attribute table. In their original inception, they both consider data in the form of an object‐attribute table. The chapter considers a debugging process in which a program is tested against different test cases. Two attributes, PASS and FAIL, represent the issue of the test case. The chapter extends the analysis of data mining for fault localization for the multiple fault situations. It addresses how data mining can be further applied to fault localization for GUI components. Unlike traditional software, GUI test cases are usually event sequences, and each individual event has a unique corresponding event handler.
Fichier non déposé
hal-04403506 , version 1 (18-01-2024)
Paternité
Peggy Cellier, Mireille Ducassé, Sébastien Ferré, Olivier Ridoux, W. Eric Wong. Data Mining‐Based Techniques for Software Fault Localization. Handbook of Software Fault Localization, 1, Wiley, Chapitre 7, 2023, 9781119291824. ⟨10.1002/9781119880929.ch7⟩. ⟨hal-04403506⟩
15 Consultations
0 Téléchargements
