A Stability Aanalysis of a Time-Varying Chemostat with Pointwise Delay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Biosciences and Engineering Année : 2024
This paper revisits a recently introduced chemostat model of one– species with a periodic input of a single nutrient which is described by a system of delay differential equations. Previous results provided sufficient conditions ensuring the existence and uniqueness of a periodic solution for arbitrarily small delays. This paper partially extends these results by proving – with the construction of Lyapunov like functions – that the evoked periodic solution is globally asymptotically stable when considering Monod uptake functions and a particular family of nutrient inputs.
Time_varying_chemostat_stability.pdf (874.78 Ko) Télécharger le fichier
hal-04412087 , version 1 (23-01-2024)
Paternité
Frederic Mazenc, Gonzalo Robledo, Daniel Sepulveda. A Stability Aanalysis of a Time-Varying Chemostat with Pointwise Delay. Mathematical Biosciences and Engineering, 2024, 21 (2), pp.38. ⟨10.3934/mbe.2024119⟩. ⟨hal-04412087⟩
43 Consultations
24 Téléchargements
