Computing minimal Weierstrass equations of hyperelliptic curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Research in Number Theory Année : 2023
We describe an algorithm for determining a minimal Weierstrass equation for hyperelliptic curves over principal ideal domains. When the curve has a rational Weierstrass point w_0, we also give a similar algorithm for determining the minimal Weierstrass equation with respect to w_0.
hal-04415457 , version 1 (24-01-2024)
Qing Liu. Computing minimal Weierstrass equations of hyperelliptic curves. Research in Number Theory, 2023, 9 (4), pp.76. ⟨10.1007/s40993-023-00483-5⟩. ⟨hal-04415457⟩
18 Consultations
0 Téléchargements
