Automating the evaluation of interoperability effectiveness in heterogeneous IoT systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Internet of Things (IoT) applications consist of diverse resource-constrained/rich devices with a considerable portion being mobile. Such devices demand lightweight, loosely coupled interactions in terms of time, space, and synchronization. IoT protocols at the middleware layer support several interaction types (e.g., asynchronous messaging, streaming, etc.) ensuring successful interactions between devices that use the same protocol. Additionally, they introduce different Quality of Service (QoS) delivery modes for data exchange with respect to available device and network resources. On the other hand, interconnecting heterogeneous IoT devices requires mapping both their functional and QoS properties. This calls for advanced interoperability solutions integrated with QoS modeling and analysis techniques. This paper introduces an automated synthesis of QoS-aware mediating artifacts. Such mediators enable the interconnection between IoT devices employing heterogeneous middleware protocols. Additionally, representative QoS models are synthesized. Leveraging these models, system designers can evaluate the effectiveness of the interconnection in terms of end-to-end QoS. We evaluate the usefulness of our approach through experimentation with a case study employing heterogeneous middleware protocols. In particular, we statistically analyze through simulations the effect of varying system parameters on the end-to-end QoS.
ICSA_2024_Interop.pdf (1.84 Mo) Télécharger le fichier
hal-04482364 , version 1 (28-02-2024)
Paternité
  • HAL Id : hal-04482364 , version 1
Georgios Bouloukakis, Nikolaos Georgantas, Ajay Kattepur, Houssam Hajj Hassan, Valérie Issarny. Automating the evaluation of interoperability effectiveness in heterogeneous IoT systems. 21st IEEE International Conference on Software Architecture (ICSA 2024), IEEE, Jun 2024, Charminar, Hyderabad, India. ⟨hal-04482364⟩
64 Consultations
36 Téléchargements
