New interface
Conference papers
Network Communications in Grid Computing: At a Crossroads Between Parallel and Distributed Worlds
Alexandre Denis 1 Christian Pérez 1 Thierry Priol 1
1 PARIS - Programming distributed parallel systems for large scale numerical simulation
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, ENS Cachan - École normale supérieure - Cachan, Inria Rennes – Bretagne Atlantique
Abstract : This paper studies a communication model that aims at extending the scope of computational grids by allowing the execution of parallel and/or distributed applications without imposing any programming constraints or the use of a particular communication layer. Such model leads to the design of a communication framework for grids which allows the use of the appropriate middleware for the application rather than the one dictated by the available resources. Such a framework is able to handle any communication middleware ---even several at the same time--- on any kind of networking technologies. Our proposed dual-abstraction (parallel and distributed) model is organized into three layers: arbitration, abstraction and personalities which are highlighted in the paper. The performance obtained with PadicoTM, our available open source implementation of the proposed framework, show that such functionality can be obtained with still providing very high performance.
Keywords : PadicoTM CORBA MPI
Complete list of metadata
https://hal.inria.fr/inria-00000136
Contributor : Alexandre Denis Connect in order to contact the contributor
Submitted on : Friday, June 24, 2005 - 5:03:40 PM
Last modification on : Friday, February 4, 2022 - 3:16:10 AM
Long-term archiving on: : Thursday, April 1, 2010 - 8:17:29 PM
Identifiers
  • HAL Id : inria-00000136, version 1
Citation
Alexandre Denis, Christian Pérez, Thierry Priol. Network Communications in Grid Computing: At a Crossroads Between Parallel and Distributed Worlds. 18th International Parallel and Distributed Processing Symposium (IPDPS 2004), Apr 2004, Santa Fe/USA, United States. pp.95a. ⟨inria-00000136⟩
Share
Metrics
Record views
248
Files downloads
279
