Résumé : Third Generation (3G) wireless systems are expected to become more and more popular worldwide, thanks to a higher quality than in current 2G. Direct-sequence code-division multiple-access (DS-CDMA) is a solution to be implemented in these systems but, due to a limited radio spectrum and more and more demanding applications, it seems likely that congestion will still be a problem. Pricing appears a simple way to tackle this problem. This paper aims at studying the impact of a per-packet static pricing scheme on the use of the reverse-link in a cell where demand (defined through the so-called utility functions) decreases when prices increase or quality of service decreases. The paper also deals with the pricing of multiple classes, since DS-CDMA supports integrated services. In a first step, we determine as a Nash equilibrium the number of customers that will actually apply for service, depending on demand. In a second step, assuming perfect power control, we find the prices and received powers optimizing the service provider's revenue. We find that in the case where potential demand always exceeds capacity, the base station's best interest is to favor only one class, but that it is not the case in the more realistic situation when considering potential demand as a random variable over time. // Les systèmes de transmission sans fils de troisième génération (3G) deviennent de plus en plus présent et offrent de meilleurs performances que l'actuel 2G. L'accès multiple par division de code et séquence directe (DS-CDMA) est une solution qui doit être implémenter dans de tels systèmes de communication mais, à cause de la limitation du spectre radio et de l'emergence de nouvelles applications de plus en plus demandeuses en d´ebit, il semble que la congestion dans ce type de systèmes restera un problème. Appliquer un modèle de tarification semble une solution simple pour résoudre ce problème. L'idée de cet article est d'étudier l'impact d'un modèle de tarification à l'usage statique par paquet sur la voix montante dans une cellule d'un réseau sans fils. Nous considérons que la demande (définie à l'aide des fonctions d'utilité) décroit quand les prix augmentent ou quand la qualité de service diminue. Cet article traite ´également d'une tarification avec trafic hétérogène car la technologie DS-CDMA supporte l'intégration de services. Tout d'abord, nous d´eterminons par un équilibre de Nash le nombre d'utilisateurs rejoignant le système en fonction de la demande. Ensuite, supposant un contrôle de puissance parfait, nous déterminons les prix et puissances de réception qui optimisent le revenu du fournisseur de service. Nous montrons que lorsque la demande excède toujours la capacité, le fournisseur maximise son revenu en servant une seul classe de service. Seulement, ceci n'est pas vraie dans le cas plus réaliste de demande aléatoire dans le temps.
